Zum Hauptinhalt wechseln
I first booted up the Laptop and it goes to a sign in screen
How am i supposed to know what the ID and passwords are? How do i get in?
Also is this normal? this is obviously not the "first use" if someone already input a login password...
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
3 Kommentare
Note: The operating system is Windows 10 64 and it is pre-installed, if it was unclear literally the first thing i see when i open the Laptop up for the first time is a sign in screen
von
Did you get this laptop new or used? Have you just tried hitting accept and seeing if it lets you in? Where did you buy the laptop from?
von
I bought the Laptop new at Amazon, this is what i bought:
https://www.amazon.com/gp/product/B011KF...
and yea i tried signing in and all kinds of combos like writing ASUS and the model and the serial number but nothing works
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
f you have no another administrator account in the system, you cannot sign in Windows to reset it. If your PC is on a domain, your system administrator must reset your password. If you're using a Microsoft account, you can reset your password online. For more info, go to the Reset your password o Windows 10 or Windows 7.
source:
https://www.iseepassword.com/reset-windo...
If you're using a local account, use your password hint as a reminder. If you've tried these suggestions and still can't sign in, you'll need to reinstall Windows.
War diese Antwort hilfreich?
Bewertung 1
http://www.lostwindowspassword.com/windo...
You could try step 5. If not, I will find you a different option.
One question, when you hit enter, does it say something about an incorrect password or something about Microsoft accounts?
If its Microsoft accounts, a different procedure is needed and the tool from the link above will not work.
Bewertung 0
Antwort hinzufügen
wanded wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 82
