Zum Hauptinhalt wechseln
Das iPhone 6 Plus mit dem 5,5 Zoll Display ist die größere Version des iPhone 6 und seit dem 19. September 2014 auf dem Markt.
1525 Fragen Alle anzeigen
Replacement screen worked but now unresponsive
So I replaced my screen with a iPhone 6s Plus LCD Screen and Digitizer Full Assembly. Everything worked great for the first two weeks and then nothing. I can see the screen and texts but can not respond as the screen is unresponsive. It does not sense my finger.
Any help what to look for before requesting a replacement would be greatly appreciated.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
Have you tried reset your iPhone? Press the power button and home button at the same time until you see the apple logo on the screen.
von
Yes. Tried that a couple of times.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Since it's easy done, try double checking that the touch/lcd connectors are properly in place by reseating them until they get locked with a light clicking sound. If problem persists after that it's probably a screen fault.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
I am waiting on a new battery that I ordered prior to reopening the phone. Once I open it, I will check all the connections and go from there.
von
Antwort hinzufügen
John Architzel wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 83
