Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
What have you tried doing so far? Unplug and replug the cables first, however it sounds like the problem is half the backlight itself died, in which case you might need a new display.
From my understanding, this display uses fluorescent tube lighting which are integrated into the LCD. I investigated changing the tubes in my 2007 iMac years ago. For that model it was impossible to extract the tubes and replace them.
How do you know the cable is bad?
von Cameron
von da stumer
von Simon Jones
