Zum Hauptinhalt wechseln
The BlackBerry Priv is a slider smartphone developed by BlackBerry Limited. Following a series of leaks, it was officially announced by BlackBerry CEO John Chen on September 25, 2015, with pre-orders opening on October 23, 2015 for a release on November 6, 2015. It can run up to Android 6.0.1.
23 Fragen Alle anzeigen
Wi-Fi Mac adress stuck at 02:00:00:00:00:00
Hello everyone,
For a few days now, i can't activate le wi-fi on my BlackBerry Priv. When I go in the option to activate the wi-fi, it keeps loading and it show no wi-fi in the list. After a few research, i've discover that the MAC address for the Wi-fi is stuck at 02:00:00:00:00:00.
Here is a liste of what i've tried to solve the problem (with no sucess):
1- Reboot the phone a few (lots of) time
2- Pull the sim card out, no wi-fi
3- Replace the sim card
4- Let the battery drain until the phone shut-off and charging it again
Hope someone will be able to help me , cause i kind of like this phone :(
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
4 Antworten
Hilfreichste Antwort
Hi Stephane,
Can I ask if the phone was purchased second hand? Also, is the phone Rooted?
If so I would recommend wiping the phone fully, if that doesn't work is flash the firmware back onto the device.
It seems that the MacAdress is either Spoofed on a software level or someone has tampered with the phone's root files...
Thanks!
Ben
War diese Antwort hilfreich?
Bewertung 1
3 Kommentare:
Hi Ben,
thanks for the quick reply !
I've purchase the phone second hand directly fron my provider and it as not been rooted. So I think the next step before heading to the repair shop is to do a factory reset.
Stephane
von
My iPhone 11 shows the same MAC address. Should I be concerned and if so, why?
von
Hi Ben my phone is the same my Mac is 02:00:00:00:00:00 no matter what device I use I need help
von
My iPhone 11 shows the same as well as my 6s. Should I be concerned? If so, why?
Bewertung 0
Hi Stephane, were you able to solved it? I have a One Plus 2 phone with Android 6.0.1 and weeks ago just happened that to me and I do not know how to fix if.
Regards.
Bewertung 0
Hi guys my priv is the same. Just shows loading but cant switch on the wifi and this problem drains battery so fast bcuz loading continues all the time
Bewertung 0
Antwort hinzufügen
Stephane Pepin wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 7
Letzte 30 Tage: 32
Insgesamt: 9,787
