Zum Hauptinhalt wechseln
LTE-Version des iPad Mini 3. Es wurde am 16. Oktober 2014 angekündigt und ist der Nachfolger des iPad mini 2.
iPad Mini 3 LTE Front Panel Replacement adhesive suggestion
There is no mention is using any adhesive during the installation of the new panel. I know that there are many different adhesives available for different purposes. I assume that some adhesive needs to be added. Please correct me if the original, softened, adhesive will remain and sufficient to properly hold the new panel, or provide some useful suggestions for what adhesive to use. For example: what about Tesa double-sided 4mm tape?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
This question was migrated from http://meta.ifixit.com/Answers.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
To do a proper repair, you should remove the old adhesive. Most replacement digitizers include adhesive strips already installed. IMHO, the adhesive that is pre-installed is not very good quality and the digitizer will generally start lifting with time.
If you keep the old adhesive, it will only work if it is still fairly intact. More often than not, much or most of it is removed along with the digitizers.
You also need different widths of tape to do a roper repair. If you are a shop, then getting rolls of Tesa Tape in varying widths is a good option. Otherwise, I would get pre-cut adhesive from a reputable supplier like BlowerTech Adhesives or TapeTemplates. For a one-off repair, removing the pre-installed adhesive on the digitizer and applying a pre-cut template is the preferred method.
Replace a screen digitizer compatible with iPad mini 3. Includes installation adhesive. Bild
Produkt
iPad mini 3 Screen Digitizer
$39.99
War diese Antwort hilfreich?
Bewertung 3
2 Kommentare:
You "point" to the iFixit replacement Front Glass product and indicate that you think that the quality of the adhesive supplied in the noted Front Glass replacement is "not very good quality". So you would prefer to NOT use the iFixit Front Glass product with its supplied adhesive - correct? You would remove the replacment product's adhesive with something else - correct?
von
Yeah, that's basically it. I have used iFixit digitizers and the quality is very good and the service/customer support is outstanding. I remove the pre-installed adhesive and install adhesive from BowlerTech. This is true regardless of where I have ordered digitizers.
This is my business so I only use the best parts I can find. If iFixit sold a digitizer without adhesive, that's what I would buy because it would save me the hassle of removing it. From an iFixit perspective, their main audience is DIY fixers so it makes sense to pre-install the adhesive...iPad repairs are already hard enough.
von
Antwort hinzufügen
Jim Dutton wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 106
