My brother killed it cutting on ground that was too steep
The spark plugs is new new gasoline cleaned float bowl main jet needle valve starts on starting fluid dies immediately
Won't start without starting fluid?
Ist dies eine gute Frage?
If you pull on the rip cord a few times then pull the plug is the plug wet. If its not then your not getting enough fuel . When resetting the need valves run them in till they bottom out . Don't over tighten then back them off 1 and 1\2 turns. hope his helps
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 6
Insgesamt: 49
