Zum Hauptinhalt wechseln
Reparaturanleitungen für Kassettenrecorder und Walkmans
85 Fragen Alle anzeigen
The Cassette deck in my car doesn't play music! Please help
It was working just fine. Then it started making these high pitched sounds whenever I had the iPod adapter playing. Now it won't play any tapes at all. The radio still works, so I know I didn't just blow out the speakers or something. It still sounds like it's spinning the tape and it doesn't eject or rewind anything.
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
The most likely culprits are
#1 the belt that controls the cassette mechanism has gone bad/loose or broken
  1. 2 the switches that control the mechanism are dirty or broken
Both would require removal of the unit from the car and you'd need to bring it to a electronics repair shop. Any decent tech would charge $75-125 to do it right. They'd also clean the heads and tape path, so it'll probably sound a lot better once they are done. good luck!
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Shelly wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 13
Letzte 30 Tage: 42
Insgesamt: 10,122
