replace driver side window
how do i replace driver side window
Ist dies eine gute Frage?
To replace the window you need to take out the inner door panel.
First you will need a trim removal tool set, one which you could buy at any autozone for under $20.
Then youll need to remove the window control, whether it is manual or electronic, you need to remove the clips holding it into the door panels. With manual windows, the clips need to be pulled out with a special removal tool ($10). Then remove thr panel from its anchors by slowly pulling out on the sides of the panel going all the way around the edges of the panel itself.
Now remove the plastic lining under the panel held on to the metal of the door by adhesive. A lot pull it off along the edges as not to destroy it. You'll reuse it later.
The inside is concealed by an interior metal panel and about 15 bolts.
There's a lot more.. I don't have the time to type it all sorry....
War diese Antwort hilfreich?
Electric window replace pasenger side door glass 1988 1500 truck
Letzte 24 Stunden: 6
Letzte 7 Tage: 22
Letzte 30 Tage: 103
Insgesamt: 1,984
