Zum Hauptinhalt wechseln
The first generation Honda CRV, produced from 1995 to 2001.
20 Fragen Alle anzeigen
How do I change the motor mounts?
The engine vibrates when I accelerate. When I change gears, the engine moves a lot.
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
Did motor mounts fix this? Kcnoblitt@yahoo.com
von
Einen Kommentar hinzufügen
1 Antwort
@rjasonford not quite convinced that this is caused by the motor mounts. I attached the Engine Removal part of the SM with this answer. That manual shows the mounts and how to pull the engine to replace those. Not an easy job.I would suggest that you check the motor and transmission mounts first. Also, rule out engine performance issues (fuel delivery, emission control etc. ) and check your vacuum hoses etc. Honda CRV Engine removal
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Jason Ford wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 1,197
