Zum Hauptinhalt wechseln
Repair guides for the KitchenAid KHB100OB Immersion Hand Blender.
3 Fragen Alle anzeigen
How to replace the motor (or perhaps just the fuse)?
My immersion blender shorted out. There was a flash of light inside the housing and now it will not work. Any ideas for how to replace the fuse, or perhaps the whole motor?
Ist dies eine gute Frage?
Bewertung 3
1 Kommentar
How to replace the fuse
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Our KitchenAid model 5KHB100 started smoking while using it. Looked up instructions on disassembly and could find none.
I took this one apart, it is not screwed and clips holding the case together, it is glued and not easy to take apart without damaging it a bit. Not made to be dismantled and repaired.
I have a couple of photos of the inside.
Time to go source a replacement.
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
Hey Garry, any tips for unsealing the glue? Did you just use a heat gun?
von
Hey Mike, I didn't but could have helped if I had used one. Just pried it apart hoping there were clips to make reassembly easier.
von
Antwort hinzufügen
Becky Piscitelli wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 11
Letzte 30 Tage: 27
Insgesamt: 1,773
