Zum Hauptinhalt wechseln
Sechste Generation der Apple iPhones, angekündigt am 12. September 2012. Die Reparatur des Geräts ist ähnlich derer älterer Modelle, Schraubendreher und Hebelwerkzeuge werden benötigt. Verfügbar mit GSM oder CDMA ,16, 32 oder 64 GB in schwarz oder weiß.
2522 Fragen Alle anzeigen
Stuck at battery logo , battery is definetly good
Hey,
I opened my iPhone 5 and replaced the battery with a new one and removed dust from the camera.
Everything went fine but the phone just won’t turn on at all. It’s stuck at the battery logo.
I tested the battery in another iPhone 5 and it worked immediately.
I also tested the “damaged” iPhone with another battery and it wouldn’t work.
Ideas?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
The iPhone 5 is prone to "pry damage" when replacing the battery. Visually inspect the logic board, preferably with magnification, along the edge next to the battery to see if there are any missing components.
There are a lot of questions on this subject on this forum as well as many videos and tutorials online. Should this be the issue, it requires a micro-soldering repair however in the case of an iPhone 5, it's probably not cost effective to do this kind of repair unless you need to extract te data from the phone.
War diese Antwort hilfreich?
Bewertung 3
Could be a problem with the IC chip (sometimes also referred to as the U2 chip) . You can probably use a charged battery but once it goes red/out it is toast, right?
Bewertung 2
2 Kommentare:
No the Battery is charged. I tried it in another phone but with this one nothing happens...
von
Have you tried unplugging all other connectors to see if this helps the situation?
Unplug front camera, back camera, charging port one by one and let me know the results.
If this doesn't help I fear it's going to be the IC chip or a motherboard issue elsewhere. A lot of the battery handling is made possible by numerous elements on the motherboard itself :/
Fingers crossed that it's one of the flexes/connectors
von
Antwort hinzufügen
Aaron Schaub wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 61
