Zum Hauptinhalt wechseln
Veröffentlicht am 16. September 2016. Modelbezeichnung 1660, 1778. Verfügbar in den Versionen: GSM oder CDMA / 32, 128 oder 256GB / Rosé Gold, Gold, Silber, Mattschwarz oder Hochglanz-Schwarz
2264 Fragen Alle anzeigen
iPhone 7 home button does not click
My iPhone 7 was submerged in water and now the home button is not working.
The Touch ID works perfectly, however, the home button does not click at all. The phone also still vibrates.
Do I need to replace the Taptic Engine? Or what do I need to replace?
Thanks in advance.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 4
1 Kommentar
I dropped my iphone 7 and the home button us not working , it does not click at all. The touch ID could not be used too. What should i do?
von
Einen Kommentar hinzufügen
5 Antworten
Gewählte Lösung
Any device that came into contact with water, especially sea water, must be properly cleaned and decontaminated before anything else. Otherwise, you can have all kinds of latent issues down the road. However, with the iPhone 7, Home Button issues are essentially the one thing DIY & third party repair shops cannot address.
I would take a look at this previous question regarding iPhone 7 Home Buttons, particularly @rany 's answer, which is excellent iPhone 7 home button not working after screen replacement
In your case, you could have a logic board issue which may be repairable but if in the end your Home Button is defective, only Apple will be able to solve your problem.
War diese Antwort hilfreich?
Bewertung 1
I've not worked on the 7 yet, but have plenty of experience on 6 models. As for the "click"...it's just a mechanical mechanism that when pressed makes contact to close the circuit (I believe). If you gently remove the home button and set on flat surface, you should be able to press it and feel the click you mentioned...if not, clean with 90% or higher alcohol to help remove corrosion that may be preventing the click or movement to the contact points inside.
Bewertung 1
2 Kommentare:
Michael, the button on the iPhone 7 is all electronic, there is no physical actuator. You should read the thread I referenced in my answer. There are a few other threads as well.
von
Thank you... I was going by the 6 button where I could hear a click...I assumed the "click" he was referring to was same...but I will read up :)
von
I bought a new motherboard for iPhone 7 Plus and now my button isn’t working? What do I do
Bewertung 0
3 Kommentare:
My iPhone7plus fell in the water..and now the home botton is not working.
von
Crazy Crai, the home button is encrypted to the original motherboard. It will never work again.
von
You need the original home button for that motherboard in order for it to work again
von
My iPhone 7 turned all the way off at 100% like it died and now the home button don’t work.. anyone know why?
Bewertung 0
my iphone s 7 home button is not clicking but its very functional and the touch id works excellent… What can i do to fix it?
Bewertung 0
Antwort hinzufügen
Adam Nevin wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 32
Insgesamt: 79,138
