Guides on how to fix and or repair common issues on the 1995-2002 3rd generation Toyota 4Runner.
The 3rd generation 4Runner is a body-on-frame truck-based SUV with Independent Front Suspension (IFS) and solid rear axle with coil springs in the front and rear.
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
1 Kommentar:
@dano1971 what exactly is going ton with your linkage (AT or MT)?
Its a AT, My shifter is very sloppy and today I could'nt you get the key out of the ignition I couldn't put it in park all the way. I have a check engine light on and the code is p1780 I changed my neutral safety switch. But the light stayed on.
von oldturkey03
