Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
What is wrong with my battery?
My battery randomly drains from time to time (like 1% every 30 seconds) and works perfectly sometimes. A 10 min youtube vid sometimes takes 2% battery while other times takes 10%.
-phone works and functions perfectly
-battery has been calibrated
-charging times are normal ~ 2 hours for full charge
-battery has been recently replaced, perfect wear level on batterylife
-not any apps or anything (checked THOROUGHLY)
-low power mode doesnt change anything
-drains 10% to 30% overnight (~8 hours) no use, no notifications popping up
-turned phone off, waited a few minutes, then plugged charger. It turned on. (if this means anything)
Is this because of a bad u2 ic chip?
Or a bad replacement battery?
Or anything else?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
Are you synced with a Mac or PC when you hook up? Diagnostic tools are different.
von
What do u mean?
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
It sounds like you are on the right track in your diagnosing...but to be sure, check battery replacement is good. Measure the charging circuit to very it is indeed putting out proper voltage to charge. It could be battery, Charging port or the charging IC (s), U2 (Tristar) or Tigress.
Update (08/09/2017)
I'm sorry, I meant you could measure the voltage using a multimeter where the battery plugs in.
Here is a youtube video link that may help.
https://youtu.be/6nrw-Q8-NI8
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Ok thank you! Im confused, what do you mean by the charging circuit?
von
Hilfreichste Antwort
I would recommend trying a new battery, if you continue to have problems then it's probably the u2 ic chip or a software issue rather than hardware. It's fairly common for batteries to be defective occasionally.
Bewertung 2
Sorry, I tried ading a link but it was removed as spam, so I'll try to ad it here to test charging circuit I answered earlier
Bewertung 0
Antwort hinzufügen
Eric Lieu wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 4
Insgesamt: 390
