Zum Hauptinhalt wechseln
Released March 2016, 7.0" Galaxy Tablet by Samsung.
40 Fragen Alle anzeigen
there is a X mark on battery icon
I dont know if its the charger or the pin in the tablet that has something wrong. When i plug the charger there is a red X mark on the battery and it wont charge. I have to power off the device in order to charge it but I need to stay the evice open because i need things in here. Help how do i fix it?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
If you are charging it via your computer, switch to a charger.
War diese Antwort hilfreich?
Bewertung 3
1 Kommentar:
No, im charging it with its charger. But there still an X mark
von
Usually this means battery is bad or near end lift. Try to use the device till battery is completely drained then full charge again. Repeat this step for 2 to 3 times and if it still happen. You need a new battery.
Bewertung 0
1 Kommentar:
I’ve got a 51 located on the battery icon. What does that mean
von
Mine does the same thing but I just got a new battery so I know it’s not a battery problem.
Bewertung 0
Antwort hinzufügen
aju shee wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 15
Letzten 7 Tage: 80
Letzten 30 Tage: 328
Insgesamt: 10,933
