Zum Hauptinhalt wechseln
Veröffentlicht im März 2016. Modell: SM-G930V.
425 Fragen Alle anzeigen
Does Device model matters?
When purchasing a replacement motherboard for my samsung galaxy s7, does it need to be the same model as the original? Mine is the G930F. Would it make a difference if i replaced it with the G930P motherboard?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Yes! Each model varies slightly, though it's enough to prevent a off model MB from fitting in your frame/making all necessary connections.
Update (08/16/2017)
Models G930A G930V G930T G930F G930FD G930P are physically all the same. The difference between them is just how they are programmed before shipment.
I have an uncommon s7 model, so I always get model # specific components...
War diese Antwort hilfreich?
Bewertung 5
4 Kommentare:
All the connection look the same and the shape is identical
von
I see one is quad core processor, the other is octa
von
@felis How do I identify a motherboard model of a died, unlocked S7? And, what is the unlocked model that works everywhere?
von
Provided that the logic board has not been changed from the dead S7, you can see the model number on the back glass printed at the bottom.
von
Yes, the model number absolutely matters.
If you get a G930P, your phone will be stuck on Sprint US, which is a CDMA based service provider.
G930A is locked to AT&T
G930T is locked to T-Mobile
G930V is Verizon
G930FD is International Unlocked with Dual SIM slot -- you will need new housing if you get this one.
Your G930F represents International Unlocked with single slot SIM.
Go to http://imei.info and put our IMEI number into the field to find more about your phone.
Bewertung 2
2 Kommentare:
But what if the phone wasn't originally accepting my sim card and I put in the correct part for the phone to accept my sim card
von
I have Samsung S7 g930 w8 model can I change its motherboard with Samsung S7 g930 fd model ply reply if any know any thing about it thanks ....
von
Antwort hinzufügen
Daniel M Musson wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 2,091
