Zum Hauptinhalt wechseln
Herausgegeben am 25. September 2015. Model A1687/A1634. Die Reparatur des 6s gestaltet sich ähnlich zu denen früherer Generationen; benötigt werden Schraubenzieher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA / 16, 64 oder 128 GB / Silber, Gold, Space Grau oder Roségold.
2690 Fragen Alle anzeigen
Bottom half of the screen is unresponsive.
I replcaed my phone screen about a month ago using one of the guiides on this website. Everything worked fine. Then out of no where the bottom half of the screen stopped working and I cant use the keyboard or anything. Im not sure what to do.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
Well a super temporary fix is to use landscape mode. Where did you get the parts from? If it was here, ifixit has an AMAZING warranty program
Here's the email for support. That's usual the best bet
http://help.ifixit.com/article/136-email...
Though their phone support has recently gotten better
http://help.ifixit.com/article/135-conta...
After that, if you haven't purchased from ifixit, I would contact whomever you've purchased it from, and see if you can't get a replacement
War diese Antwort hilfreich?
Bewertung 3
5 Kommentare:
This is the exact replacement screen i got....
https://www.amazon.com/gp/product/B01N2M...
Is there anything else I can do to fix it without having to replace the screen again?
von
Probably not. The touch not working on the bottom half is characteristic of a faulty screen. It would probably be easy to get a refund if you bought it on amazon.
von
It is now working. But I have to press a little hard to get it to respond. Could it be a partially disconnected wire or something???
von
Nah, it can't be the ic this time. Apple moved em
von
Try to reconnect the touch flex cable connector
von
my iPhone 6S bottom half isn’t working either. I cant even get into it because I need to do my password which  contains a 0 in it. when i press the 0 nothing appears to be working. what can I do?
Bewertung 3
2 Kommentare:
The bottom half of my itel smartphone is not working. I don't know what to do
von
how did you fix it
von
Mine is not working too what I have to do
Bewertung 1
Antwort hinzufügen
Jaredrett wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 22
Insgesamt: 40,836
