Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
replaced LCD screen, phone went dead. turned on several days later
So, I replaced my cracked lcd screen, which I have done plenty of times, and when I tried powering the phone on, it wouldn't. The battery was fully charged at the time. I replaced the new lcd screen and put the cracked one back again, still dead. I don't believe it was the new replacement screen since I connected the cracked screen and still had same problem. Anyways, Three days later I tried turning it on again and surprise! It works back again. Has anyone experienced this problem before? Or know what could have caused it?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Its possible that you caused a non-fatal short when plugging in the new screen. I have seen a short prevent the display from functioning even when replugged, and the device power cycled. The 2 ways I've seen devices restored to full functionality was a soft reset or a full cycling of the battery itself (drained to zero then charged until boot).
Of course this only applies if you (one of the following) left the phone on/the battery plugged in/were not properly grounded when performing the repair.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Gabby wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 46
