Zum Hauptinhalt wechseln
A1708/EMC 3164 — Veröffentlicht im Juni 2017, behält dieses MacBook Pro Einsteigermodell die traditionelle Funktionstasten bei (im Gegensatz zur OLED Touch Bar).
563 Fragen Alle anzeigen
How long does the SSD last?
Dear iFixit,
How long can one expect the SSD in the Macbook Pro 13" (without Touchbar) 128GB to last with regular use?
Thank you.
Kind regards,
Yousif
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Good question! No one really knows!
The problem here is how you use your system has a bigger bearing on its lifespan.
So someone who is a light user will find it will last a very long time. In fact I would guess much longer than a mechanical hard drive! But there is a catch! you can't leave it turned off more than a year without risk of the data from rotting out.
Someone who is doing a lot of data churning (adding and removing data) will wear the drive out sooner than what a mechanical hard drive can sustain. So in this case its not good!
I strongly recommend you do backups and rotate the drives so you know you have at least two other copies if this is your only system. If you have two systems and they are sync'ed you could get away with one backup.
War diese Antwort hilfreich?
Bewertung 3
2 Kommentare:
Dear Dan,
Thank you for the answer. But say I transfer/ move about 20GB per day, how long could I expect the SSD to last then?
von
Here's a good write up on testing to 2 PetaByte! The SSD Endurance Experiment: They're all dead
Do put this into perspective this was a test to find the breakpoint you're not likely to hit this even running 20 GB a day. But it shows you'll be chewing down your 9 lives very quickly just the same. I would figure t would take you over five years to hit 1 PB
von
Well under normal use i think it can last for more than 3 years or so on. Modern day SSDs are very reliable and they come with good endurance.
Bewertung 0
Antwort hinzufügen
Yousif N. Al-Saif wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 8
Insgesamt: 3,007
