Zum Hauptinhalt wechseln
Das Sony Xperia Z5 ist ausgestattet mit einem 5,2 Zoll 1080 x 1920 Pixels Display, hat einen Qualcomm Snapdragon 810 Prozessor, dazu eine 3GB RAM sowie eine 23 MP Rückkamera.
20 Fragen Alle anzeigen
While calling phone screen turns off?
While using any calling feature (phone, facebook, etc) my phone screen goes black and won't turn back on, if the other person doesn't hang up first than I have to manually restart my device to end a call. How do I fix this? Seems to only have started after I installed Nougat 7.1.1.
Ist dies eine gute Frage?
Bewertung 5
1 Kommentar
can i turn off that sensor that make the screen black when covered ?
von
Einen Kommentar hinzufügen
6 Antworten
Hilfreichste Antwort
Do you have a screen protector or a case that may be covering up the proximity sensor? If not, the proximity sensor itself may need cleaning or replacement.
War diese Antwort hilfreich?
Bewertung 3
1 Kommentar:
I had this problem and it was annoying, especially when I had to press the dial pad to go to different services from the number I was calling. So I googled it many times and had all these long winded methods. Then I got a post from a bloke that sounded like he was Russian. When making a phone call and your phone goes blank, just press with you finger in the right hand top corner and the screen comes on again. Thankyou Komrade.
von
Make phone call. When screen goes blank, press right hand top corner of screen.
Screens comes on again.
Bewertung 2
3 Kommentare:
Thanks for this very helpful information
von
Omg it works thank you!!!
von
2023 still using this trick. Tq very much
von
I have that problem also
Bewertung 0
Well Ensure that the proximity sensor is not being blocked by foreign objects, a screen protector, or a protective case.
Following might be helpful for you: https://wethegeek.com/how-to-fix-android...
Bewertung 0
Hi, there is 2 type of problem, first clean your sensor, usually top left of mobile phones, Second may your proximity sensor need to be replace.
Bewertung 0
i just pressed the top righthand corner and the screen came on !!!** weird or what
Bewertung 0
Antwort hinzufügen
Char Duffett wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 19
Insgesamt: 11,753
