Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
After Battery Replacement, My iPhone 6 Keeps Rebooting.
I accidentally mixed up the screws that secure the charging cover. I put them back in the right place, but now my phone reboots after about 3 min. Is there anything I can do?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
Turns out that the pins on the cable weren’t ligned up right.  They were just a little bit off, and that’s what was causing the issue.  We got them aligned right and everything worked.
War diese Antwort hilfreich?
Bewertung 0
Before you mixed up the screws, the iPhone booted properly and worked for more than 3 minutes?
Bewertung 0
2 Kommentare:
Yes, before the repair it worked normally. I also noticed, it doesn't reboot while in Airplane mode for some reason.
von
The behavior of rebooting every 3 minutes is very odd. I dont believe (could be wrong) that mixing up those screws can do damage. If memory serves me right, the screws pass through the board and not directly onto where a longer screw would do damage.
von
Before the repair, you mean with the original battery? My guess: the replacement battery is a bad one. Try another battery please.
Bewertung 0
1 Kommentar:
I put my origional battery back into my iPhone and even did a software restore, and it still reboots.
von
This looks to be a general problem on iPhones whenever thys battery replacement..I’m facing the same challenge. my 6s+ keeps restarting over and over and charge percentage is stuck after replacing the battery… gosh! quite irritating
Bewertung 0
Antwort hinzufügen
Alex Hadfield wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 15
Insgesamt: 2,112
