Zum Hauptinhalt wechseln
The HP Flyer Red is a laptop created by Hewlett Packard which was released around December 2014.
31 Fragen Alle anzeigen
help with my laptop
i have reboost my laptop but it says the computer restarted unexpectedly or encountered an unexpected error. Windows installation cannot proceed to installed windows click ok to restart the computer and then restart the installation. but eveytime i press ok the little window keeps showing up with the same thing
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
Which version of Windows do you have and do you have any important data on it?
von
In addition to version info etc can you put picture or exact quote of the error message and at which point in the installation it occurred?
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
This could be either a hard drive problem or memory problem. If you can access the internal diagnostics by pressing F2 when you see the HP splash screen, select the component menu and select hard drive or memory. There may be a fast test and a more intensive test for the hard drive or the memory, it is better to use the intensive tests. If the tests work OK then the problem may be the medium you are using to install Windows is corrupted.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Duyneska Marie wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 64
