Zum Hauptinhalt wechseln
Das iPhone 6 Plus mit dem 5,5 Zoll Display ist die größere Version des iPhone 6 und seit dem 19. September 2014 auf dem Markt.
1525 Fragen Alle anzeigen
Why is my iPhone randomly opening apps, taking pictures, typing letter
My Iphone is a hand me down but it didn't have any problem up until i received it. It types random letter and opens apps. Sometimes ill knock it a little bit which helps sometimes. I've restarted it over and over thinking that it would solve the problem but it hasn't. Maybe its a screen issue?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 4
1 Kommentar
My micro cracked screen iPad does the same thing.
In fact it locked me out from Apple ID so severe, I had to
have Apple Support live on the phone two different days
to solve it on laptop to get back in,,
Making sure iPad had no access to network..
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
There are a few things that can cause what you are experiencing but yes...I would start with a screen replacement after checking that all the connectors are seated properly. Remember...1. Power off phone 2. Unplug battery 3. keep track of screws that hold the shield on, they have to go back into same hole they came out of 4. when disconnecting the connectors, be gentle...you don't want to knock off little components or damage the flex cables.
Here is a guide that may help you
War diese Antwort hilfreich?
Bewertung 4
2 Kommentare:
I had the same issue and replaced my iPhone 6 Plus with a new one. It continued to happen so I searched more on the web and saw comments about static electricity... I decided to wrap my phone in dryer sheets to remove the static and it now works perfectly
von
I'll tell my husband to do the same thing Robin.
von
Maybe the touch issue, reconnect the LCD screen or change a new replacement to have a try.
Bewertung 0
iPhone typing by itself -problem fixed. As it was typing crazily, I simply tapped on the little square icon on top, left side of keyboard (next to the microphone icon). It was instantly fixed. Couldn’t believe it.
Bewertung 0
Antwort hinzufügen
tristan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 31
Insgesamt: 59,729
