Zum Hauptinhalt wechseln
Die fünfte, auf Android basierende Generation der Galaxy Smartphones von Samsung ist seit dem 11. April 2014 auf dem Markt. Zu den Verbesserungen gehören der Fingerabdruckscanner, eine erneuerte Kamera, ein größeres Display und Wasserresistenz. Es ist in vier verschiedenen Farben verfügbar: Schwarz, blau, weiß und kupfer.
577 Fragen Alle anzeigen
Frage geschlossen
How do I access the letters instead of numbers on the dialup pad
can`t find anything on the dialup pad to change numbers to letters
Ist dies eine gute Frage?
Bewertung 15
14 Kommentare
That's the way it will look. For instance, when someone's phone number is 1-800-CALL-NOW, their number is actually 1-800-222-2-555-555-66-666-9. That's how it looks. The letters are just so you can spell things in a phone number, but it's still just a number. To the dialer letters are just numbers.
von
No answer …same question..how the !&&* do I access the letters and symbols on my Samsung Galaxy 7 phone key pad?
von
I won't my old letter back I can read it
von
How can I do this for a password with some numbers and some letters. It does not know what I am saying because it is not a word..
von
I have this problem, Human resources in my country lets me speak the first 2 passcodes they need to let me talk to someone then I'm asked to input a third which ends in a letter, (this is new) there is no way I have found to input anything but numerals, we are not talking about the corresponding letters assigned to each numeral on the keypad so we can work out what "1-800-CALL-NOW" is but to actually input a letter.
von
9 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
5 Antworten
Hilfreichste Antwort
That is what you dialer should look like. To use the letters under the numbers, enter the number to the count of the letter you want to use. For instance, if I wanted to enter the letter B, I press two twice. If I wanted to enter O, I press 6 three times. Understand?
Hope this helps!
War diese Antwort hilfreich?
Bewertung 3
4 Kommentare:
thanks for your advice George. I pressed 2 twice, but all that came up was
2 twos. same with o, up came 3 sixes. What do you think?
von
Sounds like tom wants his password to be a word instead of a number. Like using the letters on a standard dial up phone to spell it out. For example WORD would be 9673
von
The answer given by George A. is totally wrong. The answer given by mayer is the correct answer.
von
Some carriers require a letter in the passcode to unlock the phone. I was FORCED to use a letter and now my phone is bricked because I can't type a letter after a system update.
von
Its not helping cause have tried so many times if l press 2 twice it gives me 22 while l need alphabet
Bewertung 2
1 Kommentar:
Its doing my head in
von
How do I get the letters on my phone dial pad ?
Bewertung 2
3 Kommentare:
von
So give me right way
von
Hi just discovered on my phone. Hold down the required key for a few moments and this works.
von
I went into my actual ‘pair a new device’ part of my phone and it came up with the complete keyboard!
Bewertung 0
You push the number associated with the letter I need
Bewertung 0
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 126,800
