My charger plug won't plug in.
My charger plug seems to be blocked from plugging in.
Ist dies eine gute Frage?
Does it seem to be blocked by an object in the plug? If not, does the connector seem fine and not damaged? It that looks fine, have you tried a different cable just to be sure that it is not the cable that is bad?
War diese Antwort hilfreich?
1.Lighting the charging port to see if there is something else.
2.Check whether the cable and charging port are in good condition? If the cable is damaged, change a new one to have a try, if the charging port is damaged, you should replace a new charging port.
Letzte 24 Stunden: 1
Letzte 7 Tage: 14
Letzte 30 Tage: 15
Insgesamt: 160
