Zum Hauptinhalt wechseln
Das Apple iPhone 5s wurde am 10. September 2013 angekündigt. Die Reparatur dieses Geräts ist ähnlich wie bei den Vorgängermodellen und erfordert Schraubendreher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA mit 16, 32 oder 64 GB in silber, gold und space grau.
3530 Fragen Alle anzeigen
iPhone 5S stuck on logo
Hi,
my iPhone 5s was working fine until I put it on charger in car and instead charging it went off. It got stuck on battery logo with lightning cable showing on screen regardless on what charger I put it on. I tried different cables, wall chargers etc with no luck.
Few days later, I tried to change battery and charging outlet, again with no luck.
Finally I have took logic board out and put it into another iPhone 5s case with all remaining parts from the 100% working iPhone. As a result, I am getting boot loop or iphone is stuck on logo.
I am able to turn it off by power+home button, however if it's connected by cable it will not turn off and just tries to boot again. Also, when it's off and I connect it by cable to PC it will start itself and again to boot loop / logo stuck, but PC does not recognise the device.
I tried DFU but assuming the cable supposed to be pluged in, I am not able to turn off the phone while cable is connected. It start itself and loops.
Any thoughts please?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Those cheap car chargers wreak havoc on the iPhone charge circuit. You likely blew the Tristar IC on the logic board. This will require a micro-soldering repair and is not a DIY fix.
Look for a reputable micro-solderer in your area or check out for those that do mail-in repair.
War diese Antwort hilfreich?
Bewertung 2
Solution 1. Restart your iPhone to fix iPhone stuck on Apple logo
Solution 2. Fix iPhone stuck on apple logo with iTunes (Data loss)
Solution 3. Fix iPhone stuck in apple logo without restoring (No data loss)
Detailed guide: How to Fix iPhone Stuck on Apple Logo
Bewertung 0
Antwort hinzufügen
Dew wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 1,841
