Zum Hauptinhalt wechseln
1,4GHz oder 1,6GHz Prozessor, 64 GB oder 128 GB SSD.
162 Fragen Alle anzeigen
Mac Air late 2010 does not turn on
Power Adaptor is connected, charging is normal (orange light is lighted on the adaptor connector).
No signs of life and no welcome chime after I press Power button, except for the cooling fan turning on after a minute.
PRAM reset (Command-Option_P-R keys pressed) and SMC reset (Shift-Option-Command-Power on buttons depressed then released) have not helped.
Any other ideas, guys?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Review this Apple T/N: Apple Portables: Troubleshooting MagSafe adapters
An Orange MagSafe LED that never turns Green often implies the battery is not charging. It also can be a bad battery as well.
War diese Antwort hilfreich?
Bewertung 1
4 Kommentare:
Orange light turned green after 2 hours. So it's a good battery and charger.
von
Can you give us some background here on what this system has encountered. Like did it get a bang or get wet as some point? Was the system running and then shut it's self off?
von
I last used the laptop 2 weeks ago and kept it in the storage drawer.. Now, it is kaput. No one touched it for the duration it was stored.
von
Dead systems on the most part need one to test for voltagages from the battery to the different power rails on the logic board.
You'll need access to the schematics, can read them, as well as have the needed tools to probe the logic board. For most, this is beyond a DIY job. Sorry :-{
von
Antwort hinzufügen
Bernie wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 5
Letzte 30 Tage: 6
Insgesamt: 820
