Zum Hauptinhalt wechseln
The Samsung Galaxy S5 NEO (SM-G903F) has a 5.1 inch Super AMOLED display with Full HD resolution. It's front and back cameras clock in at 5 megapixels and 16 megapixels respectively.
Charging when they isn't a charger plugged in
My phone seems to charge on its own when they isn't no charger plugged in it fort it was my battery at first but then I've changed battery's I changed it about last week or so and it's still does it does anyone know what it means?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi!
My Microsoft Lumia 950 did the same thing and replacing the battery did not fix it for me. However, I did not give up and after opening it up I noticed that a fuse blew off the board, so I had to get that replaced. You can follow this guide on how to get to the charging daughterboard in your phone if you wish to replace it yourself.
Otherwise have a technician fix it for you.
War diese Antwort hilfreich?
Bewertung 1
3 Kommentare:
So does that mean it's something to do with the mother board? Thanks for the answer
von
Not the motherboard, but the small daughterboard, where the charging circuitry is.
von
Oh right thank you I was about to say my motherboard only got fixed this year.
von
Antwort hinzufügen
Zoe wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 13
Insgesamt: 270
