What is fault 49
What dose I need a service ,fault 49 mean .
Ist dies eine gute Frage?
@stevew Error Fault Condition – Water Inlet Valve Fault.
Repair or Check – Unplug the washer from power. Reconnect any non secure wires on the water inlet valve. Replace the wire harness if it is found to be damaged. If the wiring is okay then measure the resistance of the water inlet valves using an ohm meter. If the resistance of each water inlet valve solenoid is not 60 to 62 ohms then replace the complete water inlet valve assembly.
Parts for Replacement – Water Inlet Valve Assembly or Wire Harness from here
War diese Antwort hilfreich?
have replaced the water inlet valve but code is still coming up
Letzten 24 Stunden: 18
Letzten 7 Tage: 59
Letzten 30 Tage: 249
Insgesamt: 14,081
Hi,I have this fault on my fisher and paykel washer. The wiring harness looks fine,I replaced the inlet valve and the fault is still there. Any idea what else it could be?
von Jamster
I too am in the same situation. would love further guidance
von gap423
Have you got the solution?
von danishinnz
I too am in the same position; water pressure there, no visually obvious blockage of the valves, wiring looks fine, resistance is measured but, still get the same fault code.
von rob_ldk
Hi @rob_ldk
Have you checked that there is voltage be applied to the valve when it needs to be operated?
Be safety aware as the valve operates at mains supply voltage value i.e 120V AC or 240V AC depending on location.
von jayeff
7 weitere Kommentare anzeigen
