Zum Hauptinhalt wechseln
Released 2016, January, identified by model number K430T. The type of display is IPS LCD capacitive touchscreen, 16M colors and a 13-megapixel camera.
My screen is cracked and chipped at bottom.
I have an lg k10. I was at work and dropped my phone on floor. The screen is cracked in different spots and chipped off at bottom corner. Can I just replace screen or what do I need to fix this problem?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Assuming it is just the screen assembly that needs to be replaced you should be able to find a replacement part online readily. I would normally recommend getting the part on the plastic frame if available. They are relatively inexpensive phones and screens look to be in the $40 range, this device might be more inexpensive to replace. If that is the route you take please recycle the device.
How to disassemble LG K10?
http://www.ebay.com/itm/New-For-USA-5-3-...
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
John lacy wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 10
Insgesamt: 1,258
