Zum Hauptinhalt wechseln
Modelle A1181 / 1,83, 2, 2,1, 2,16, 2,2, or 2,4 GHz Core 2 Duo Prozessor
1203 Fragen Alle anzeigen
Why my MacBook doesn't detect MagSafe charger?
Hi,
i have a problem with my black 13" MacBook. Sometimes MacBook didn't detect MagSafe charger. I say didn't because it doesn't charge my MacBook now.
When i connected adapter to my laptop green led doesn't bright. Other times it charged, but now it can't. With the battery it works perfectly, but i don't have other MacBook to charge battery in it.
I try with other charger without results. I think it could be DC-IN or Logic Board. I try DC-IN with a multimeter, and pins one and five are connected, second and fourth also and the center pin it's not connected to other pins. Without battery laptop doesn't power-on, because charger isn't detected.
I would be very gratefully about any help.
Thanks
Regards
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Pins 1 and 5 are grounds. Here's the pin out: http://en.wikipedia.org/wiki/MagSafe
Check the AC adapter to see if the pins are extending and if they are charged. If it's OK then I would replace the MagSafe port. Here's how to do that: MacBook Core 2 Duo Magsafe Board Replacement
War diese Antwort hilfreich?
Bewertung 2
3 Kommentare:
Thanks for your response. I'm pending to receive a DC-In board, when i tried it i post if it solve my problem.
Regards
von
Solved. I changed the DC-In board and Macbook charges perfectly.
von
Glad I could be of assistance.
von
Antwort hinzufügen
josuku wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 4,661
