Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
iPhone 6 glass only replacement left bubbles
The shop that I work at has acquired a plate type laminating machine to use for glass replacement on phones, due to the rising cost of full display replacement these days This is the machine we have.
I have been trying to iron out the process, but I am still getting bubbles under the glass almost every time. Posted is a picture of my most recent attempt.
Can anyone offer any advice as to why this is happening and how to avoid it? We are using glass with pre-applied adhesive.
Ist dies eine gute Frage?
Bewertung 1
2 Kommentare
It looks similar to a problem I've seen in the past. Does your machine use a vacuum pump to seat the glass?
von
Yes it does have a vacuum pump
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Your machine's vaccum pump is used to keep the pieces from sliding around during the binding process and to remove SOME of the air bubbles, but those pumps typically aren't strong enough to remove ALL of the air bubbles. For that you need a bubble remover, also known as an autoclave (which isn't entirely accurate since it's not a sterilization chamber, but people use the name anyway so I will too). After you've finished the relamination you put the finished assembly in the autoclave for a minute or two which pulls out ALL of the air bubbles from the assembly. Some vacuum lamination machines have a built-in autoclave, others do not. I'm guessing yours doesn't.
(PS: I have a vacuum laminator w/autoclave for sale, if you're interested.)
War diese Antwort hilfreich?
Bewertung 1
4 Kommentare:
This machine is listed as a 2-in-1 OCA Plate Type Laminating Machine 12" Vacuum Built-in Pump and Compressor. It is supposed to remove bubbles as part of the process.
von
Based on your info and pic I found your machine on ebay, and according to all of that it does seem like it has a debubbler as part of the process. From the looks of the design it seems that the autoclave part has been incorporated into the vacuum lamination part, and is secured (rather awkwardly, IMO) by those four eye bolt-type pieces at the top (what they call "fixing nuts" on page 6 of the manual). That being the case, I would suspect that it's not holding a proper seal. A true autoclave uses a removable screw-on door to ensure an even 360 degree seal. Using four manual screws like that seems like a cheap workaround to me since there's a very good chance of an uneven seal. If there's a break in the seal, even a tiny one, the vacuum will pull air from that seal rather than from the bubbles in the screen (since the damaged seal will have less resistance).
von
Okay, so I've run the glass through the machine a few more times, heating it up on a hotplate between cycles and the bubbles are getting smaller. I think I know where are least part of the problem is coming from though. I had been leaving the glass in the mold because the instructions I was following mentioned putting the glass in the mold but never mentioned removing it or that the mold shouldn't be in with the glass. So I'm hoping my problems are due to that mistake since the videos I've watched today don't have the mold in them. EDIT: Also the seal does seem to be holding since the pressure is staying at 100 psi without the pump reactivating during the 10 minute process.
von
That sounds reasonable to me. When I laminate a screen I take it out of the mold to put it into the autoclave, though in my case it's because my machine has two separate places for the lamination vs debubbling process (plus the mold won't fit in the autoclave).
von
Hello. What happen when using only bubble remover without using laminating machine?
Does the all bubbles disappear without using laminating machine and skip straight to te bubble remover?
Thanks
Bewertung 0
Antwort hinzufügen
Amos Doughty wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 8
Insgesamt: 1,174
