Zum Hauptinhalt wechseln
Mitte 2009 Modell A 1278 / 2,26 oder 2,53 GHz Core 2 Duo Prozessor EMC 2336
745 Fragen Alle anzeigen
Green charge light won't change to amber, MacBook won't start
The magsafe connector stays lit up in green, and I assume my battery is dead, because I haven't used this machine for a while. I googled. I tried the control-option-start button trick, no love. I opened the machine, disconnected the battery, waited a while, reconnected and tried again to no avail.
Not long ago, I checked the battery condition and it was good. So, no charge getting to it I think. Could this be the magsafe card, or the DC?
Any and all suggestions/diagnostic tips appreciated.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
By chance did you have a liquid spill at some point? This sounds like liquid damage.
Your logic board is the likely suspect here. Within it is the power control logic which switches the MagSafe power to either the battery charge or running the system or both! Something in this logic or deeper in the CPU logic has a problem.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
Thanks, Dan. No spills, no abuse of any kind. This machine mostly stays put, at a cabin I keep up in the mountains. My research leads me to either the Magsafe card or the DC controller, just hoping someone might have had this experience and figured it out.
von
Do you leave it there during the winter? It can get quite cold! That could explain things here.
von
Antwort hinzufügen
nicejob wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 76
