Zum Hauptinhalt wechseln
Das Sony Xperia Z3 Compact kam im September 2014 auf den Markt.
82 Fragen Alle anzeigen
Antenna Board REplacement for D5803
Dear Comunity,
I am having the exact same issues described in No Service at all thread for the regular z3. The suggested solution is to replace the antenna board.
I cannot, however, find said article for my version of the phone and am a bit lost as to what I can do. The two phones probably do not have the same hardware, right?! Do you think it would be a possible solution to try and only exchange the antenna cable? This one can be found for the d5803.
Thanks,
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
@alb3rt you are right, there isn't one. You can try to replace the cable first. Sony does no longer have any schematics available for their phones. Here is the recommendations according to the service manual for No or bad network. Use these guides Sony Xperia Z3 Compact to work on your phone.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
@oldturkey03 ok, thanks for the helpful comment. I'll try replacing the cable first then. might come back here with further questions though.
cheers
von
Antwort hinzufügen
albert einstein wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 4
Insgesamt: 1,223
