Zum Hauptinhalt wechseln
Apples 2016 Überarbeitung, ihres auf professionelle Benutzer ausgelegten Laptop Lineups. Es ist ausgestattet mit einem 15 Zoll 2880 x1800 Retina Display, einem quad-core Intel Core i7, mit 256GB / 512GB / 1TB / 2TB Speicherplatzoptionen, 16 GB RAM Arbeitsspeicher und einer Tastatur mit einer Touch Bar. Es erschien im November 2016. Modell: A1707.
127 Fragen Alle anzeigen
MacBook 2016 touchbar after only 1 week use won’t turn on
I just broke my MacBook Pro!
I had fully charged it, then travel with plane when I arrived, it didn’t work. I tried resetting SMC, I tried holding the power button in different scenario, I even opened her up disconnected the battery and no luck, I was wondering where are the power pads to jump start the mac?
And what do you guys think happened ?
I did set an appointment but it’s in 10 days and I really need my computer!
Thanks
Ist dies eine gute Frage?
Bewertung 1
Kommentare:
Bummer, Sorry to hear about your computer. Did you spill anything on it during the plane ride?
von
Einen Kommentar hinzufügen
2 Antworten
Unfortunately, the 2016 and 2017 MacBook Pros no longer have power on pads.
Update (10/06/2017)
I would try booting it in minimum configuration. Disconnect everything from the logic board, and then plug it into power. The 2016 and 2017s now auto boot when plugged into power. If it is booting in minimum configuration, then you can add components to see what is causing the problem. If it still does not boot the logic board will need replaced.
War diese Antwort hilfreich?
Bewertung 0
Kommentare:
whether the fan is removed too
von
i see, any suggestion ? i had this problem with macbook 2011-2013 and when i disconnected battery and reconnected it it was fixed but in this one nothing helps
Bewertung 0
Kommentare:
See revision to my previous comment.
von
Antwort hinzufügen
mehrad raissi wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 1
Letzten 7 Tage: 2
Letzten 30 Tage: 13
Insgesamt: 1,718
