Zum Hauptinhalt wechseln
Der Logitech UE Boom 2 ist ein wasserdichter, tragbarer (IPX7) Bluetooth-Lautsprecher mit 360°-Sound. Er ist in vielen leuchtenden Farben und Mustern erhältlich.
45 Fragen Alle anzeigen
UE Boom 2 speaker broke after being in water
Completely made sure all of the ports with sealed shut and proceeded to use my speaker for the first time in the water. DID NOT COMPLETELY SUBMERGE IT, it was probably in about 1 in of water for 10 minutes when the speaker shut off.
It will not work anymore.
Was advertised to be waterproof for up to a half-hour in about 1 meter of water?
Ist dies eine gute Frage?
Bewertung 1
4 Kommentare
There are some limits here! It's not really intended to be used as an underwater speaker only survive a dunk turned off. {https://www.gizmodo.com.au/2015/09/ue-bo...|UE Boom 2 - The Best Bluetooth Speaker Is Now Waterproof For The Same Price]
von
Dan , unfortunately I do have the UE BOOM 2, which is the water resistant one. Advertised to be able to work in 1 meter submerged for 30 min.
von
Hi Nicole, the same happened to my it boom 2. It was submerged partly for barely 2 minutes and it hasn't turned on since. Did Logitech help you out?
von
Similarly I left my wonderboom a float for bearly 1 min and after doing so it makes a static noise as if water had entered the speaker.
von
Einen Kommentar hinzufügen
7 Antworten
Hilfreichste Antwort
If your UE Boom 2 refuses to turn on, see the UE Boom 2 Won’t Turn On problem page for possible causes and solutions.
Water probably got into the Headphone/DC port. Since they did advertise as water-resistant, I would contact Logitech to see if they can do anything about a replacement.
War diese Antwort hilfreich?
Bewertung 3
1 Kommentar:
That won't work. They'll only help if it came defective or DOA, but if you caused it, then they don't care.
von
Make some story up.... I got mine replaced same thing happened with me
Bewertung 1
Why won’t my UE MEGABOOM speaker work after it had been submerged under chlorine water ? It makes a deep tone and shuts off .
Bewertung 1
1 Kommentar:
Hey Nicole same thing happened with me but also the company told that even if you left the port open nothing would happen. This is just ridiculous because such a high price for a speaker but the build quality and durability is just awful. The company should at least make it better or provide better service for repair. Jbl speakers are just better in waterproofing.
von
I have a wonderboom and i researched to double check if it was water proof and it said yes and so I had put it in the water and now it is temperamental with turning off or on and is stuck on sound down so when I turn the sound up it automatically turns it down again
Bewertung 1
1 Kommentar:
Mine turns off and on all the time and bass isnt working
von
Mine was left in the rain, now it won’t charge.
Bewertung 0
my megaboom can't on or charge after expose in shower about 30 minutes
Bewertung 0
I think some lawers should prepare a lawsuit against logitech for defective products and lack of accordance between the published characteristics with the negative to replace woonderbooms after being summerged either with the usb port cap on or off.
Bewertung 0
Antwort hinzufügen
[deleted] wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 2
Letzten 7 Tage: 25
Letzten 30 Tage: 86
Insgesamt: 10,996
