Zum Hauptinhalt wechseln
Erschienen im Frühjahr 2014. Ausgestattet mit einem 5,5" Bildschirm. Ursprüngliches Betriebssystem war CyanogenMod 12S. Modellbezeichnung "ONE A0001"
110 Fragen Alle anzeigen
Installed a replacement screen - Vertical flickering issue
See this video: https://streamable.com/ktkw1
This only happens when the screen is turned on, either when the phone is booted up or awaken from sleep. This issue happens for a few mins then it goes away. The screen looks fine afterwards.
Touchscreen functionality is OK.
I would like to know if this is a defect in the replacement screen or something I messed up during installation i.e. connection etc?
Can someone also explain what is causing this issue? And why does it go away after a few minutes?
Thanks!
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
It's hard to pinpoint the exact reason for this issue, but the problem may arise because of poor connectivity to the phone's "motherboard" or chip, from pressure on a portion of the LCD that was created during reassembly, or simply environmental factors like heat or cold air. I would recommend reassembling the device. If the condition continues it may be safe to look for a replacement LCD.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Muhammad Sarwar wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 216
