technically that's a picture of a headphone plug. Specifically it looks to be a 1/8 inch/3.5mm TRRS plug (tip-ring-ring-sleeve.
I'd strip a bit of insulation on the insulated wires and test for continuity between the 4 contacts on the plug, and the 4 conductors.
If it follows the established standard, starting with the tip is the left audio channel, first ring is the right audio channel, second ring is a return channel for an independent audio signal, and the sleeve is a common ground/shield.
The uninsulated (Silver) one is probably sleeve/ground/shield
If you have a voltmeter with alligator clamp or grabber leads, you should detect continuity between the uninsulated wire and the sleeve. Strip a bit from one wire clamp it on one lead and touch the other lead to the other three positions on the plug. Hopefully only one of them will show conductivity and then you'll know which contact on the replacement jack to solder that wire to.
The other possibility would involve taking the headset apart and tracking it down from the other end.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
