Zum Hauptinhalt wechseln
The Dell Inspiron 15R 5520 laptop features a 14.88" screen, brushed aluminum finish and features a i5 core processor .
Broken Headphone jack. Is it fixable>
Long story short, I broke my headphone jack on my Dell Inspiron 5520 a while ago and today was the last straw. Is it possible to replace the entire jack without doing and soldering? Here's the part and I dont know if it just sits in place or if it requires soldering.
https://www.aliexpress.com/item/Audio-Ja...
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi!
The broken headphone jack needs to de-soldered from the motherboard and replaced with the new one, that needs to be soldered back on. At the same time you need to use a special soldering iron (or a very good one) to melt the solder. Also, laptop boards are very complex and usually multi-layered, therefore using a soldering iron could break some traces or parts on the other side with no visible damage, aggravating the problem. A more elegant solution would be replacing the entire board or even taking it to a computer repair shop.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Desmond Waters wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 24
Insgesamt: 496
