Zum Hauptinhalt wechseln
Vierte iPad Generation mit GSM, erhältlich seit dem 2. November 2012 mit 16, 32 oder 64 GB Speicherkapazität. Modellnummerb A1459.
43 Fragen Alle anzeigen
Why Ipad 4 GSM no modem firmware after update?
After update to 10.3.3. (via ota) there's no modem firmware and always searching (imei is OK), then restart after some minute.
I've restored (via itunes) with same 10.3.3, then everything is OK, but after 2 days, when i insert sim (ipad in airplane mode) the same things happened :
searching & no modem firmware.
It was working well for 5 years, now my ipad is useless.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Such type of fault mostly appear after the force brick.This actually happen when baseband chip is not working as well or damage.If you have idea to open search on ifix it and rehot the baseband chip or search for faulty parts near baseband chip.If the problem is still same you have to replace it.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
i have a plan to open it and try to fix it by myself, could u please show me where's the baseband chip position is ? if u can attach the image i will appreciate it...
thanks.
von
Antwort hinzufügen
Andrew Liem wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 347
