Zum Hauptinhalt wechseln
Herausgegeben am 25. September 2015. Model A1687/A1634. Die Reparatur des 6s gestaltet sich ähnlich zu denen früherer Generationen; benötigt werden Schraubenzieher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA / 16, 64 oder 128 GB / Silber, Gold, Space Grau oder Roségold.
2690 Fragen Alle anzeigen
TouchiD issues with new iOS?
I am a shop and have repaired 1000's of phones-
Anyone experiencing fingerprint issues with current iOS after screen replacement?
The phone shows no failed touchID message, just doesn't see the finger to scan.
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare:
Have you updated to 11.0.3?
Have you done a Settings --> General --> Reset --> Reset all settings (NOT ERASE CONTENTS AND SETTINGS)
von
Thanks for your reply
As I mentioned I’ve repaired 1000’s of phones. I know all about bad home buttons, dirty, or erasing and re-scanning.
The issue was on 3 different phones today all 6s. All normal everyday screen repair. iOS doesn’t show “failed”. It simply doesn’t see the scan. When trying to put a new print in it just sits and waits as if there is no finger on the button.
Current supplier says they have had calls on this issue over the last few days and are looking into it.
Hoping posting here I might get a quicker answer
Thanks again for your input
von
Einen Kommentar hinzufügen
1 Antwort
When I upgraded to IOS 11 upon release, there was a known issue regarding TouchID that affected my iPhone 6, and I had to delete my saved fingerprints and re-scan my fingers to solve this.
However, it did give me a failed TouchID message when it failed. I would say try to re-scan your fingerprints first, if that doesn't work, there may be an issue with the print scanner in the home button, it could be worth replacing the home button.
Before commencing repairs or taking it to a repair service, make sure you take some basic steps such as cleaning the home button of dirt, grime, etc, and ensuring that both your finger and the button are dry.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
mazzolagregory wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 212
