Zum Hauptinhalt wechseln
Aufpolierte Version des iPhone 3GS mit schnelleren Verarbeitungsgeschwindigkeit. Die Reparatur geht ähnlich wie beim 3G vonstatten und braucht nur einfache Schraubendreher und Hebelwerkzeuge. Modell A1303 mit 16 oder 32 GB Kapazität mit schwarzer oder weißer Kunststoffrückseite.
1502 Fragen Alle anzeigen
Screen turns on by itself - dock connector?
I got a broken iPhone from eBay, when I put it back together it worked ok, but a ribbon cable on the dock connector assembly was broken. The microphone etc. did not work.
I bought a "new" dock assembly on eBay, but since putting everything back together again the screen lights up and displays the unlock slider about every 20 seconds. It does not do this when playing music, or when plugged into the computer.
Having googled it looks like it might be a faulty dock connector - does anyone know whether or not this is the case? I also replaced the headphone assembly and vibration motor, but I installed these yesterday before the dock connector.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
I've established that is is the dock connector. A message briefly flashes up now about an incompatible accessory, and when I use the old dock connector it works fine.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Well done on fixing your problem- pretty strange! Thanks for posting your solution, learned something new which is always good. Please change your comment to a solution, then accept it as an answer so others can see your solution worked!
von
Mmm.. It can't be the Dock connector, it must to be a slack screw, make sure the board is fastened by all the screws, if its not, wash it it isophropylical alcohol, but its definitively not the dock conector. :D
Bewertung 0
1 Kommentar:
What is isophropylical alcohol????really bad predictive text?? LOL :-)
think you might have got this one wrong ichris.... Louisanilsen fixed her own problem . And it WAS the dock. Learn something new everyday...
von
Antwort hinzufügen
louisanilsen wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 1,687
