Zum Hauptinhalt wechseln
Ein Samsung Smartphone, erschienen im Januar 2016. Modell SM-J320
Phone touch screen not responding Samsung J3 [J320n]
after doing a hard reset the touch screen is still unresponsive. also when it was dropped initially about 10 hours ago the left side of the screen had a tiny crack. any ideas on what could be broken? Screen or motherboard?
any help?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Jack Nicolsen you cannot make the determination without working on it. The number one give away on here is this "dropped initially about 10 hours ago" and " the left side of the screen had a tiny crack" You have a failed digitizer. Replacing that will resolve your issue. This video should help you with that. Don't start soldering on the board until you have properly checked everything else.
War diese Antwort hilfreich?
Bewertung 1
I just cleaned the digitizer port contacts with contact cleaner and it worked.
Bewertung 0
Antwort hinzufügen
Jack Nicolsen wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 11
Insgesamt: 8,271
