Fan running really loud
Hi, about 1 month ago I spilled a little bit of coke on my MacBook Air 2017. I turned it off really quick and cleaned it with isopropylic alcohol and a tooth brush. After doing this, it turned on again, but it worked really slow, with the fan working really loud. Apple diagnostics gave error PFM006 and a camera error. Again I proceeded to clean it again, but more in detail. After cleaning the logic board, the computed went back to normal.
Today, after 5 days of working normally, the fan started to run really loud again. The difference now is that the computed works at perfect speed.
After using temperature gauge, it gives every temperature normally (in green), except for one which appears and disappears which is "PECI SYSTEM AGENT". The fan is running really fast, at 6500 RPM, and the sensor diagnostics says that the GPU sensor might not be working properly.
Please I need some kind of advice to solve this problem, im really disorentiated.
Thanks in advance
Ist dies eine gute Frage?
