I have problem in the screen
I have laptop Acer V3-771 and i have problem in monitor :
The problem is : the output for the screen is white color.
I wont solve for this problem .
Ist dies eine gute Frage?
@qutaiba72white screen means that the backlight is on but your display does not receive any data. Check with an external monitor and see if that displays properly. If it does, you know that you GPU is circuitry is working. Check the cable to your LCD and you may have to replace the LCD. If it does not then your issue is with the GPU so you will have to check on the motherboard. For that you would need the schematic
War diese Antwort hilfreich?
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 21
Insgesamt: 340
1 Kommentar
Thank you very much for your advice
von Qutaiba Saoor
