Water leak in refrigerator?
Does the drain that's behind freezer panel that has to be remove to get to it.does it drain into drain pan. I try to take drain pan out from my FRS6HR45KSO . But I couldn't so kept searching and found there was a small screw holding plastic in on bottom side, so as I'm applying pressure on bottom I seen water dripping from two screws toward front. Apparently water got into bottom compartment. Can a bad door gasket cause condensation to build up and leak into bottom of compartment . I still can't take out drain pan it said she lift up and pull out but no it is jam in there tight . Thank you for your help
Ist dies eine gute Frage?
