Zum Hauptinhalt wechseln
Dents repair cost Lenovo Yoga 710
I dented 2 corners (directionally diagonal) of the bottom part of my Lenovo yoga. They don't seem to be causing any damage, but I'd like to get them fixed if it's not too expensive. Do you have any idea how much this would cost?
Mimi Smith
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Hi @mimiasmith ,
Here is a link to the service manual for your Ideapad.
Scroll to p.32 to view the procedure to remove the base cover.
Here is the part number for the base cover 5CB0L47369. (p.70 in the manual)
If you search online using the part number only, you'll get suppliers of the part and an idea of the cost of a replacement cover.
Hopefully this is of some help.
Replace a scratched or cracked lower half of the main case. Bild
Produkt
Lenovo IdeaPad Yoga 710-15 Lower Case - 5CB0L47369
$59.99
War diese Antwort hilfreich?
Bewertung 2
Well this is an interesting one. First thing first, Lenovo sucks for replacement unique parts like the back plate of a yoga. I also have never seen a shop offer the option to fix dents in laptop bodies either. So unless you can find someone to go around with a real tiny rounded tool, I doubt it can be "fixed" but instead replaced. And with some searching around, I can't find any source for back panels for a yoga. So your only real option left would be to buy a dead yoga that you can use for spare parts, and that will be hard to find. So if you can find someone to buy a back panel off of, thats pretty much your only real bet.
Bewertung 0
Antwort hinzufügen
Mimi Alexandria Smith wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 24
Insgesamt: 1,729
