Zum Hauptinhalt wechseln
The HP Spectre 13-3010dx is a high end, lightweight, HP touchscreen laptop.
13 Fragen Alle anzeigen
How to recover my file from a dead spectre laptop.
i have an hp spectre laptop. My model is 13-4005dx , i noticed after powering on i heard an explosion inside the laptop and it went off. Now i want to recover my files urgently, how do i do this? Taken into consideration it's a ssd hard drive.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi @eke ,
Here is a link to the service manual for your laptop.
Scroll to p.28 to view the necessary pre-requisites and then the procedure to remove the SSD.
Once you have it removed you should be able to insert it into another PC with the appropriate mSata connection as an extra drive and hopefully retrieve your files or you may have to purchase an adapter to suit your "host" computer's available spare connection type, e.g. there are mSata to sata adapters, just search online for the appropriate type.
Hopefully this is of some help
War diese Antwort hilfreich?
Bewertung 3
Antwort hinzufügen
ekene duaka wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 782
