Zum Hauptinhalt wechseln
PC-Laptop von Dell mit einem 15,4"-Display. Nachfolger des Inspiron 1520.
Why can't my Dell Inspiron 1525 charge the replacement battery?
Battery doesn't hold any charge.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
3 Kommentare
Is it a new battery that you're trying to use?
von
No, it's an old replacement battery and the electrical cord is used as well. Has been worked on prior times, not me. Trying to save the laptop since it's my only backup and my Mac doesn't have microsoft cause I can't afford to buy the approved programs.
von
Use this : Dell AC Adapter LA90PM130
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
Ok so what I would do is look for a replacement battery on Amazon, like this one:
Dell Inspiron 1525 Battery - Amazon
Try using that, and it should work just fine.
- Jasen
War diese Antwort hilfreich?
Bewertung 3
if Ur useing a new battery then u probably need to replace the charger port
Bewertung 0
I have replace the battery & also replace the charger port , then same problem could not charging the battery…..
now what can I do…..?
Bewertung 0
Antwort hinzufügen
Maria wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 16
Insgesamt: 664
