Zum Hauptinhalt wechseln
Verfügbar seit Mai 2014 / Display: 540 x 960 Pixel, 4,8 Zoll, 16M / Chipsatz: Qualcomm MSM8926/MSM8226 Snapdragon 400 / Android OS v4.3 (Jelly Bean), aktualisierbar auf v4.4.4 (KitKat)
Not Charging : Dead
Hi Team,
Sony Xperia M2 - Dead Unit.
Device status & measurements :
The fault is Phone is not charging, USB Power ( 5V, 10-20 mA) Battery Charging voltage 1.1 - 4.1V, current fluctuating.
Note : This is liquid damaged device
Observations & tests
  • TH voltage is 1.2V it seems OK
  • There is no BAT EN signal 0.6V
* Phone can be power on when given the BAT+ - to with external power supply
  • When plug the battery connector 0V at battery terminals. that's mean Battery Disable itself
  • When unplug the battery and can be get measurement 3.7V
  • Checked with new battery, same result observed. - Battery is OK
If any idea please comment. Thank you for your time. in simple i need to enable BAT EN signal or need a way to bypass. or Please help to find schematic diagram for D2303
Ist dies eine gute Frage?
Bewertung 2
1 Kommentar
Buddhika Mahesh this is going to be tough. There are no more schematics available since Sony does not repair any electrical components anymore.
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Buddhika Mahesh the only thing you could try is to hack it together like this
from here
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
Already checked the path. 2-3 Ohms. 4.9V there. i need to generate anyhow BAT_EN signal. otherwise have to replace PM IC.
oldturkey - As always, Thank you for helping us! :-)
von
Buddika mahesh im from sri lanka is there a way to contact u
von
Antwort hinzufügen
Buddhika Mahesh wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 21
Insgesamt: 3,047
